stock or aftermarket fuel pump?
Old Dec 11, 2005 | 07:25 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
well, looks like i get to change my fuel pump, so what's the recommendation? stay with stock, or go with an aftermarket one? probably gonna be changing the sending unit, too. reason for pump change is because wiring shorted out, most likely in the pigtail outside the tank, so having to drop it... engine is slightly modified, as in worked heads and bigger cam... this would be my '91 5.7L TPI, btw.
Old Dec 11, 2005 | 08:12 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Id say go ahead and replace it with an aftermarket one. I got a pump from TRE and it works great.
Old Dec 11, 2005 | 08:48 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
http://www.racetronix.com/product/RX..._Pump_Kit.html
Old Dec 13, 2005 | 11:25 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
STICK WITH AC DELCO!!!!!!
Old Dec 14, 2005 | 06:23 AM
contact's Avatar
Engine: sbc 350
could two stock-pumps, be put in parallel?
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
