fuel running out of intake
Car: 89 IROC, 85 Z28
Engine: 350 TPI, 305 Carborator
Transmission: 700R4, none
so i bought this car and i did a tune up on it this fall, it is a 89 IROC with 350 tpi, well after the tuneup it still wasnt runnin right. well after a month or so (today) i tried startin it, it started up on the second crank no problem, untill it started stumblin and died, i cranked a few more time then poped the hood and took the aircleaner off to check for a mouse nest or somethin (just a hunch), but i didnt find anything so i decided to take the MAF sensor off and when i did a river of gas ran out of the intake. Now to me that seems a bit queer and i was wonderin if it happend to anyone else and if they would share the causes and any soulutions.
thanks
thanks
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Sounds like the diaphragm in the fuel pressure regulator went bye bye.
Pull the vacuum line off the regulator(in rear under plenum) and see if it has gas pouring out to confirm your fears.
No big deal.
Pull the plenum to get to the regulator.
later
Jeremy
No big deal.
later
Jeremy
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Also, don't crank the engine with the runners full of fuel, because it'll hydraulic and may break things. Pull the spark plugs, disconnect the coil, and have a fire extinguisher ready.
- had a zz4 hydraulic once at work, oops. no damage, but a nice starter and a good battery might cause something to let go.
Car: check
Engine: check
Transmission: check
Originally posted by tzenda
would this also be a cause for fuel running out of the tail pipe??
RBob.
Fast355
Dec 2, 2016 06:33 PM
86IROC112
Aug 17, 2015 02:00 PM
