Disassembly Help On Exhaust Manifolds
Old Jan 8, 2006 | 05:38 PM
bonz's Avatar
Car: 89 GTA
I am corrently trying to take off my exhaust manifolds, however the bolts that are attached to the dip stick and heat shields I can only turn so much and then they bind with the heat sink or dipstick bracket and it just bends them until I cant turn it anymore. What do I need to do to get them off.
THANKS for the help.
Old Jan 8, 2006 | 07:52 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
PB Blaster them. Warm engine for a minute or so, and PB Blast them again. Tighten them, loosen them, repeat, until you can get them all the way off.
Old Jan 8, 2006 | 08:59 PM
bonz's Avatar
Car: 89 GTA
Not quite sure what PB blaster is also the engine is semi torn apart so I wont be harming it up. is it because they are rusted to the bolts or what.
THANKS
Old Jan 8, 2006 | 09:50 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
There are jam nuts on the studs holding those parts on.
Get the top nuts off, then the studs will come out.
Soak'em with WD or whatever and they should come off.
A backup wrench under there at the stud will help if you can get it in there.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
