#1 dist. cap terminal
Old Jan 19, 2006 | 12:15 AM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Which terminal is the #1 on the distributer caps which starts the firing order? Does it matter? If so or not, why? Please explain using my pic. I know the firing order and how to index the distributer.
Old Jan 19, 2006 | 12:31 AM
Vader's Avatar
Old Jan 19, 2006 | 12:45 AM
Dirtbik3r's Avatar
I understand that Vader, but the cap turns. How do I know the exact position the distributer cap should be in to match up with that diagram and firing order?
Old Jan 19, 2006 | 01:04 AM
Vader's Avatar
EDIT: Oh. I now see you have a '92. That will have a separate ignition coil (smaller diameter cap) and therefore it makes little difference how the distributor is installed. Simply position the wires on the cap in their correct relative locations, and set the base timing as usual. If the wires are not in the correct positions, just move them all an equal number of terminals in the correct direction.
If the distributor has been removed and not installed in the factory orientaion, you're going to be starting from scratch. Actual position is really not critical.
Old Jan 19, 2006 | 09:49 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
both of the plugs should be facing the firewall. the plugs I speak of are the ignition module plugs
Old Jan 19, 2006 | 12:34 PM
Shagwell's Avatar
Car: projects.......
when you find TDC(finger in whole method, and drop the dist in, #1 is which ever post you point the rotor at. If you want a different order to your wires, simply pull the distributor and re-install after turning it to where you want it. - no, it doesn't matter which post you use, as long as you start w/ #1 and then 8436572...
Old Jan 19, 2006 | 05:53 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I didnt read any of the responses, sorry.
Simply, when you have #1 piston @ FTDC and have inserted the dizzy, the rotor MUST point in the #1 terminal. So, in effect, it all depends on how you drop the dizzy in!!!!!!!!!!!
Old Jan 20, 2006 | 11:48 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Accually the 2 plugs should be facing about 2 o clock with the firewall. Theres a notch on the distributor that lines up with the notch on the intake manifold.
sheachopper
Jul 31, 2019 11:27 AM
school boy
Oct 22, 2015 11:47 AM
LT1Formula
Oct 8, 2015 08:34 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
Damon
Sep 26, 2015 04:29 PM
