Need help on this
Old Jan 26, 2006 | 07:35 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Need help on this
I have a TPI 1991. I have two nb o2 sensors
one on the right side and one on the left side in
the header pipe and they are in the same place
on both sides.
What would cause the right
side to run alot richer than the left side at idle.
The left side does not register at idle, but
does when I get on it and it reads
the same as the right side.
Old Jan 26, 2006 | 08:43 PM
fireball451's Avatar
Car: 91 Z28, 91 Z28, 92 Z28
Engine: LB9, LB9, L98
Transmission: T5, T5, 700r4
Axle/Gears: 3:42, 3:42, 3:23
I only have one o2 sensor on both my '91's.
Never seen one with 2.
Old Jan 26, 2006 | 09:14 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
You are right this is not stock this
was added to the header pipe
one both sides
