Injector wire/connector test?
Old Feb 2, 2006 | 11:08 AM
jackballs529's Avatar
Car: 1987 Iroc-z
Engine: 355/Edelbrkhds/lpe219cam/MiniRam/
Transmission: 700R4/3.27 9bolt
Guys,
In the spring, I am doing an injector swap to the Fords but I want to check the wiring and connectors that attach to the injectors. I have a Superram intake so this is virtually impossible to do with the intake on. So when I have the Superram off, I would like to run some kind of a test to verify that the wiring and connectors are working correctly. Any idea on how to do that?
Old Feb 2, 2006 | 11:57 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Take out the fuel pump relay (and disconnect the oil switch) so the fuel doesn't spray and use a noid light on each of them while cranking. Each one should pulse if they are ok.
Old Feb 2, 2006 | 11:59 AM
Car: 1987 Iroc-z
Cool thanks, were are the relay and switch?
92projectcamaro
Jan 18, 2016 08:00 AM
BAMiller
Sep 14, 2015 06:38 PM
greenyone
Sep 2, 2015 03:39 PM
Jae992
Aug 27, 2015 09:07 AM
