dyno tune?
Old Feb 17, 2006 | 12:27 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
dyno tune?
Everyone i call says alls they can do for me is timing and adjust the fuel pressure..i thought there was more to it then that? Correct me if im wrong, i dont know much about dyno tuning
is it because my car uses speed density and a prom?
I sched with a company to do 2 pulls and get the wideband o2 data and i guess ill figure out what im going to do from there... (its only 65$ to do this..while tuning and 3 pulls or more is 150$ an hour)
any suggestions?
Old Feb 17, 2006 | 12:31 PM
Guest
Guest
Posts: n/a
They likely dont have the hardware and software to make changes to the prom.
Old Feb 17, 2006 | 01:07 PM
Car: 1991 Z28
Engine: SBC
that's what i figured...dammit. well at least ill get 2 dyno pulls to see what im making..
Old Feb 17, 2006 | 03:24 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
How far are you away from Jacksonville, Florida. There is a guy there that will do more than that.
http://www.dynotuneperformance.com/
Old Feb 17, 2006 | 04:15 PM
Shagwell's Avatar
Car: projects.......
Vinci perf. in Orlando also does OBDI ecu dyno tuning, but at the money, either DIY prom or switch to an aftermarket ecu...then if you change something else down the road, you're not dropping another $500+
Old Feb 17, 2006 | 06:16 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
We dyno tune ourselves at the dyno for $75 an hour with up to 10 pulls as a group.
Old Feb 18, 2006 | 07:41 AM
Car: 1991 Z28
Engine: SBC
Im real close to orlando...about an hour away and jacksonville im not too far away either. Can i get an address to the orlando one?
and if i switched to an aftermarket ecu..what are my options?
Old Feb 18, 2006 | 10:39 PM
Car: 1991 Z28
Engine: SBC
anybody?
Old Feb 19, 2006 | 01:39 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
The Jacksonville place still does tuning for aftermarket ecu's.
LT1Formula
Oct 8, 2015 08:34 PM
