How to remove underhood fuel lines?
Old Mar 1, 2006 | 03:13 PM
Abubaca's Avatar
Alright, last time I did this, half the motor was missing, and everything was a mess. I just did my best to get all the fuel in a bucket, but I wasn't really concerned about mess.
This time I'm just removing the rubber fuel lines between the hardlines. Is there a proper way to do this, or do I simply make a mess and clean up later?????
Old Mar 1, 2006 | 09:43 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
dumping fuel out is pretty much it.
loosen the gas cap before you loosen any of the fittings.
you can bleed off the fuel pressure at the pressure test port with your gage, it helps some.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
3rdgenparts
Aug 8, 2015 07:09 PM
