Need Help With Injector Sizing
Old Mar 2, 2006 | 11:59 AM
GTA350VORTEC's Avatar
Car: Black on Black 1989 GTA
Engine: 5.7L Vortec TPi
Transmission: 6 Speed T56
Axle/Gears: 3:73
I am currently running a GMPP 5.7L Vortec 330hp Tpi with 52mm throttle body, headers, MSD 6AL, stock computer, stock injectors in a 1989 MAF GTA. I am having trouble figuring out if I should purchase the 21lb injectors or the 24lb. Would any of these changes require computer reprograming? Or shoud I just stick with the 19lb injectors. I've done alot of searching but havent found a direct answer...any help would be greatly appreciated...also If left any important info out please ask....thanks again
Old Mar 2, 2006 | 12:55 PM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
I'd step up to a 26# injector. Considering the TPI will probably choke the motor a little on the HP side, you'd probably be safe with 24#ers. Definately too much HP for 19# injectors.
Old Mar 2, 2006 | 02:28 PM
Axle/Gears: 3:73
will I have to reprogram or burn another prom for my computer if I use the 24lb/hr Injectors? or will it run normally and not overly rich. I'm also not running an EGR at all, and no CAT.
Old Mar 2, 2006 | 02:32 PM
Duts87ss's Avatar
You will need a new chip burned.
Old Mar 4, 2006 | 10:41 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I'm currently running 24# injectors with the stock 43.5 pound pressure. My duty cycle is at 80% at the highest point. I'm at the 330RWHP mark. However with my next round of upgrades I will be going to the 30 pound injectors as I'm getting close to the limit of the 24# injectors.
Old Mar 4, 2006 | 05:09 PM
Axle/Gears: 3:73
How can I learn about chip burning? is there any sites or books that list the programs and hardware needed to accomplish this? Since I definately want to step uo to at least the 24lb injectors. As far as burning the new chip what has to be changed? is there a default program I can use?
I'm new to chip burning so any help would be extremely appreciated. Thanks Again
Old Mar 4, 2006 | 09:39 PM
Duts87ss's Avatar
Check out the DIY PROM section of this site.
92projectcamaro
Jan 18, 2016 08:00 AM
toronto formula
Nov 10, 2015 06:17 AM
Brother Al
Oct 14, 2015 06:39 AM
BAMiller
Sep 14, 2015 06:38 PM
