Wire in ECL or get scan tool. Input please.
Old Mar 2, 2006 | 05:49 PM
CochinoFilipino's Avatar
Car: '67 C10
Engine: 5.0 TPI
Axle/Gears: Yes
I have picked up 67 Chevy Truck with TPI and 700R4. It does not have an Engine Check Light wired in. But it does have the ALDL port.
I’m not sure exactly what I’ve got yet. The PO said it was a 5.7TPI from an 84 IROC. But I know that can’t be right.
I’d like to be able to pull codes. I think that I need to figure out how to wire in an engine check light so I can do the jumper thing. Or buy a scan tool.
(Preferred) If I wire in a light, I need to know how. I’ll need a wiring diagram.
($$) If I get a scanner I need to know which one to get.
Input please.
Thanks,
Other info;
The numbers on the MAF are:
Bosch
0 280 213 002
14 081 243
The ECM appears to be after-market. The sticker reads:
BWD Automotive Products ECC 7165
OEM Reference;
1227165
16198259
16198445
Old Mar 2, 2006 | 06:55 PM
Car: '67 C10
Engine: 5.0 TPI
Axle/Gears: Yes
Okay, I went for a ride and noticed that there was a light wired in there. So I tried the jumber thing and got nada. Not even the 12 to say it's doing it's thing.
Old Mar 2, 2006 | 11:39 PM
Vader's Avatar
You can wire a light fairly easily. Supply a 12V+ source from an ignition switched circuit to a lamp, and connect the other side of the lamp to the 'D' terminal of the ALDL connector:
Old Mar 3, 2006 | 12:34 AM
Car: '67 C10
Engine: 5.0 TPI
Axle/Gears: Yes
Just the info I needed. Thanks.
Old Mar 5, 2006 | 03:02 PM
Car: '67 C10
Engine: 5.0 TPI
Axle/Gears: Yes
Well, that would've been perfect. But whoever did the swap decided not to hook up the D' terminal to the ALDL connector.
midge54
Dec 27, 2019 04:14 PM
italiano67
Dec 11, 2016 09:21 AM
cougar20th
Aug 27, 2015 08:04 AM
g.l.mos
Aug 22, 2015 12:02 AM
marcusaw
Aug 10, 2015 08:13 AM
