TPI to Carb????
Old Mar 20, 2006 | 10:06 AM
ndamron's Avatar
Car: 82 Trans-Am / 83 Trans-Am
Engine: Major Mod SBC / Minor Mod SBC
Transmission: Major Overhaul 700R4 / Stock 700R4
Axle/Gears: None!!! / 3.73 posi disc...soon
TPI to Carb????
Has anyone done this???
Is it a real big pain in the A$$???
Any good websites out there with information on the swap?
~Nick~
Old Mar 20, 2006 | 09:31 PM
bill3969's Avatar
Car: 89 IROC
Engine: 5.7L TPI
Axle/Gears: 3.08
summit has a kit to adapt the TPI heads to a regular intake w/carb. All it consists of is a few bolts and some adapters
Old Mar 20, 2006 | 09:40 PM
ndamron's Avatar
What about all the computer control???
What about the gauges?
~Nick~
Old Mar 22, 2006 | 03:22 AM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
I did it on a 87 Z28. With that year I just left all the gauges and sending units hooked up, they work without the computer.
I hotwired the stock in-tank fuel pump to run when the ignition was on and ran a Mallory return style regulator ($70ish, #4709 sticks in my mind, not sure if that is accurate) to get the pressure down to a carb friendly level. Used a Holley throttle/TV cable bracket w/ a 750 vac sec holley. Used a TCI vacuum controlled torque converter lockup kit ($70ish as well) to lockup the converter. Was never 100% happy w/ the lockup control, in OD accelerating w/ light throttle it would often fluctuate annoyingly back and forth between locked and unlocked in high gear.
I think that about covered it for that year of car, a newer TPI car w/ electronic speedo sending unit and junk may require more work, not sure.
Anyway, whole setup worked fine for about 2 years with a 350 w/ Vortec heads etc, then my stock in tank fuel pump died (had over 150k miles on it). I swapped on a mechanical carb-type fuel pump and put a piece of fuel line hose in place of the stock in-tank fuel pump. That worked fine for another year or so before the car then was totalled (while it was parked) by a 16 year old girl in a V6 Mustang...
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
