Pre-Cut MSD Wires for 86 TPI
Old Mar 28, 2006 | 12:57 AM
JDubya18's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 LB9
I tried a search on here but came up with nothing. I was looking at summit trying to find the MSD Super Conducter wires that are pre-cut to fit for my 86 IROC but I came up with nothing. I know they have the universal wires,but im not sure of the fit on those and they also have wires for the 85 and 88 but not for 86 or 87.So my question was what would be the best route to go with this? Will the 85 wires work? 1985 MSD Wires
Old Mar 28, 2006 | 02:05 AM
skidude's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 5.7 TPI, L98
Axle/Gears: 3.42:1
super conductor wires
You may want to check into the universal wire kit. I just put a set on my '87 GTA. I was reluctant at first, but then I decided to go for it. The uni. wire set comes ith both std. and HEI boots. It also come with a special crimper with a wire stripping guage built in. It does take a little longer to install these, but I think they are worth it.
All you need is a razor blade and a small vise.
Old Mar 28, 2006 | 03:10 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
or you can try this one:
http://store.summitracing.com/defaul...-31409&FROM=MG
was thinking about getting these for her 88 formula
but i have a spare set of MSD Full Size Balzer Truck Wires i am going to use
don't think it matters, since they are 90 boots
Caspar
Jun 19, 2016 11:19 PM
toronto formula
Nov 10, 2015 06:17 AM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
Sanjay
Aug 12, 2015 03:41 PM
