Injector part numbers
Old Mar 30, 2006 | 12:53 PM
TPI 85 Blazer's Avatar
Car: 1985 full-size Blazer
Engine: 350 Goodwrench
Transmission: custom 700R-4
Axle/Gears: 9.5" 4.88 with discs and anti-wrap.
Hello. I'm new to this board, but expect to be here quite a bit as you guys are the TPI gurus and I am working on a TPI install into my Blazer.
I want to know what injectors I have. The part number on them is 17122683 from Rochester Products. They have a pink band and a white band on them.
I'm also confused about the horsepower capabilty vs. flow rate. Different calculators lead me to anything from 260-360 max HP from stock 350 injectors. Does this vary by application?
Thanks for your help.
Old Mar 31, 2006 | 08:22 PM
The only specs I've found are here: http://www.caspeed.com/multec-injectors.html. I'm really hoping this is right. With the modification I found here to make the FPR an AFPR, it shouldn't be a problem to feed my 350. The Goodwrench 350 is rated 240-260hp with a carb and headers, so I'm thinking the TPI and a better cam can get me to 300.
BTW, sorry if it's evil to put Camaro parts in something else.
1992 Trans Am
May 10, 2023 07:19 PM
twest2k2
Aug 24, 2015 11:26 AM
355sbcTPI
Aug 19, 2015 04:38 PM
IrocZ'85
Aug 17, 2015 06:24 PM
armybyrd
Aug 10, 2015 09:23 PM
