March Under Pulley
Old Mar 31, 2006 | 06:21 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
March Under Pulley
anyone using the power and amp series kit from march?
4400 part number?
just wondering how it is for daily use, any cooling issues?
did you feel the gain, etc?
Old Apr 1, 2006 | 06:43 AM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
I am running the 4410 set and sofar so good, I'll know more by the end of summer.
Old Apr 1, 2006 | 08:17 AM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
I have an L03 305 TBI with the March Underdrive pulleys (crank, and ALT. pulleys). I noticed a difference shifting into second gear. Nothing huge, but enough to say there worth it. It did not effect the idle much, but my lights will dim slightly at a red light, and the vents blow a little softer while at idle also.
Old Apr 1, 2006 | 12:47 PM
MdFormula350's Avatar
4400 Power & Amp, 2-piece, Gloss Black Steel
I have them, i did a tranny rebuild and smaller diameter torque converter.
the car runs the same temp as before as far as i can tell.
the voltage is slighty above 13 volts, so its charging nicely.
power steering feels pretty good as well.
Very happy with the set. Last night i had the headlights, fog lights, cd player, and fan all on, and it took it like a champ.
also not sure if its due to the smaller torque converter, but the car starts even quicker and faster, meaning the starter seems to be turning over fast. most likely do to both things. less drag on the belt, and less roational weight to spin as well.
not sure what alternator i have but its not the factory stock one, it fits just like factory though. probably from one from advance auto, its 5 years old and still going.
i wanted to test it after putting on the new pulley, so i took it to advance auto and it was defintely charging, but not to full spec; which isnt a problem since the crank pulley matches it with it back on the car.
Old Apr 1, 2006 | 04:11 PM
Vader's Avatar
Dummass. MARCH is over. You need APRIL underdrives now. Jeesh! Where do all these guys come from?
Thirdgen89GTA
Nov 26, 2015 11:04 PM
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
