What to do with fuel lines whilst engine is out of car? Fuel leaking!
Old Apr 19, 2006 | 07:14 AM
Dr G's Avatar
I'm in the process of an engine swap due to a dropped valve and a smashed piston. I'm wondering what to do with the fuel lines in the engine bay that are disconnected.
At first I had the ends of the lines covered by clear polythene and taped, but noticed a significant pooling of petrol in the bag. This seems to have lessened now I have taken the fuel filler cap off. I also tried clamping the rubber section of lines but was still getting the leak.
1. Is there a way to 'plug' them? What size of fitting would you use?
2. Should the gas cap be left off?
3. Should I drain the fuel tank?
Many thanks for any advice!
Old Apr 19, 2006 | 11:41 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
it happened because your cap was on, leave it off, no problems.
Old Apr 22, 2006 | 06:54 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
you could also try raising the lines up instead of letting them just hang there. i forget what i capped mine with, but wasn't leak proof anyways so i just raised them straight up and used a piece of wire to hold them that way.
Old Jun 11, 2007 | 05:11 PM
Dr G's Avatar
Re: What to do with fuel lines whilst engine is out of car? Fuel leaking!
What I did was raise them slightly, wrap them in a small plastic bag and elastic band, covered by a rag, And then unscrewed the gas cap to relieve the pressure and there were no more leaks for the several months it was off the road.
specialized
Jun 18, 2022 09:26 AM
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
86IROC112
Aug 17, 2015 02:00 PM
Kaweh
Aug 9, 2015 02:54 PM
