MAF repair! Worked for me, MIGHT for You
Old Apr 21, 2006 | 05:01 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
Hi All,
Not saying this will work in every situation. Anyway my friends TPI was runninng like crap, MAF codes all over the place. Needed a MAF. So I told him he needs to spend $$$ or try to fix it and see what happens. So i got the Idea of cleaning the MAF wires( brake cleen) then wait about 30 mins and used a blow torch on the wires just like a second or two every couple seconds till cherry red. Let it sit for like 30 mins plugged her in and fired her up bam she runs like new. Like i said won't work in every case, just use your comman sence.
Old Apr 21, 2006 | 05:48 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Brake fluid, blow torch
Old Apr 21, 2006 | 06:48 PM
Tims 88gt's Avatar
Car: Mustang
Engine: 302
Transmission: 5spd
Axle/Gears: 8.8 with 3.73
no need to heat it red hot. that could melt it.
Old Apr 21, 2006 | 07:00 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Be sure to let us know how long it lasts until it fails entirely.
Old Apr 21, 2006 | 07:02 PM
Tims 88gt's Avatar
Car: Mustang
Engine: 302
Transmission: 5spd
the only thing with making it red hot, is it may be brittle now.
Old Apr 21, 2006 | 07:11 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
The wire gets red hot in the burn-off mode. Your friend probably had a good MAF and a bad relay. Great diagnostic job. Pray you didn't overheat any part of the circuit
Old Apr 24, 2006 | 10:13 AM
8UpAFord's Avatar
Car: 1988 Corvette
So far so good. not brake fuild Homer Brake Kleen
specialized
Jun 18, 2022 09:26 AM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
86IROC112
Sep 7, 2015 01:37 PM
NBrehm
Aug 25, 2015 11:49 PM
perZ
Aug 15, 2015 01:17 PM
