what size injectors
Old May 10, 2006 | 09:16 PM
snapping turtle's Avatar
what size injectors
What size injectors do you think Ii whould need for a 383 with about 400 hp at the crank (on the motor ). It has a 150 hp dry shot of n20 , trick flow heads , super ram ,hooker long tubes , 4" mufflex exhust . I am chaging the cam to the lpe219 cam with 1.6 rr's . The car has 24 lb injectors in it now . I am sure they are near there limit . I was told maybe 32 lb . Thanks for the help .
Old May 11, 2006 | 06:33 AM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
i was going to say around 30lb ones, so 32 isnt a bad guess either.
Old May 11, 2006 | 08:39 AM
cheese_kake's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Whatever size you go with, just make sure you dont go too high because then it will throw it off completely.
92projectcamaro
Jan 18, 2016 08:00 AM
toronto formula
Nov 10, 2015 06:17 AM
Brother Al
Oct 14, 2015 06:39 AM
BAMiller
Sep 14, 2015 06:38 PM
