Searched for the last 2 hours Injector?
Old May 29, 2006 | 09:01 PM
dcjredline's Avatar
Car: 1989 Formula 350
What is the correct impedance of the injectors on a 1989 formula 350 TPI?
GM service manual is hiding it from me, and Haynes says 11-14ohm
I have 4 between 18.0 and 18.2 the others are 6.8,9.6,6.7,and 14.8
Car is running like A$$, eratic idle, crappy performance when warm and PI$$ING ME OFF BADLY!!!!
Old May 29, 2006 | 09:29 PM
83 scrambler's Avatar
Car: 83 CJ-8 (Scrambler)
Axle/Gears: (F)Dana60/(R)GMcorp14/locked 4.11
i think i recall that anything below 12 is to be considered bad. i think mine are around 17-18. been a while since i messed with that. i know there are some posts on here somewhere about the resistance tolerance.
_________________________________________________________________________________________
i found the thread for ya
https://www.thirdgen.org/forums/tpi/...esting+12+ohms
Old May 30, 2006 | 11:30 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yep, they are bad. Typical Multec failure. Toss them in the trash and put in a set of Bosch. Can get the SVO F*rd/Bosch injectors at a decent price.
RBob.
Old May 30, 2006 | 04:16 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Like Rbob said.
Trash them and go SVO.
Anything below 12 is garbage per GM manual.
If u replace the 3-4 bad ones the other 3-4 will fail and come back to huant you.
later
Jeremy
Old May 30, 2006 | 09:43 PM
dcjredline's Avatar
Thank you all. I was pretty sure thats the problem but it is always good to hear from others!!
BTW my name is Don and I live in Upstate NY WHAT UP EVERYONE??!!
Old May 30, 2006 | 09:46 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
hey if u want some injectors, im selling some ford svo's 30# injectors.
https://www.thirdgen.org/forums/engi...injectors.html
they all register 16.xx ohms.
Old May 30, 2006 | 09:53 PM
dcjredline's Avatar
Too big but thank you for the offer. I am looking at keepin the car close to stock so the biggest I am interested in is 24#. Thanks again though.
Old Jun 1, 2006 | 01:51 PM
sophinity's Avatar
Car: 1992 Miata
Axle/Gears: Ford IRS 8.8" 3.08
Looking for 19#?
I have a set of the Ford ones
I am running 26# so I probably won't use them?
Let me know?
Old Jun 1, 2006 | 06:29 PM
dcjredline's Avatar
Sorry again, I should have said it right out when TraviZ asked I would need 22#'s if I were buying them. I am watching on ebay at the moment to try and win some used SVO's
Thanks sophinity and I am sorry I didnt specify
Old Jun 2, 2006 | 02:36 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
with used injectors make sure they back them up that the impedence is good or u will have the same problem.
Old Jun 2, 2006 | 09:57 PM
dcjredline's Avatar
Yes I will dont worry. I do NOT want this same problem again!!!!
Andrew6.688
Dec 13, 2015 10:59 AM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
mrestrictrplate
Aug 27, 2015 09:37 AM
Bstrang6
Aug 26, 2015 11:39 AM
86IROC112
Aug 21, 2015 07:20 PM
