whats the difference
Old Jun 1, 2006 | 09:52 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Whats the difference between the 1986 and 1987 manifold base?Do they have different bolt patterns or angels or what?or is there any difference.Thanks
Old Jun 8, 2006 | 08:00 AM
Vader's Avatar
The '85 and '86 TPI intake base has the old intake bolt pattern, with holes drilled perpendicular to the intake flange on the head (at a 90° angle), whereas the '87 and later intake base has the center two holes on either side drilled at a 72° angle to allow easier assembly and access, and more room to enlarge the runners.
The intakes can be interchanged with very little modification.
69GTOby
Apr 18, 2016 02:34 PM
BAMiller
Sep 14, 2015 06:38 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
