Porting TPI plenum and runners
Old Jun 7, 2006 | 08:12 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
is there any information on porting/port matching the TPI intake setup?
i tried searching didn't see anything photo wise or instructions wise
can it be done with a dremel?
or would i need an air tool for it?
i'm just looking to make what ever minor improvements i can since i am swapping the heads, figured good time to tweak it
since i'm staying somewhat relatively stock, i don't see the need to go with something like the edelbrock intake/runner kit
or aftermarket runners and such, unless they really add a benefit
open to ideas
basically swapping heads and adding shorty headers
Old Jun 7, 2006 | 08:29 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
uhh if you're doing after market heads i think you would get a pretty good gain from aftermarket runners and base.
Old Jun 7, 2006 | 08:39 PM
skidude's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 5.7 TPI, L98
Axle/Gears: 3.42:1
just heads?
Just my
There's no way I would go through the trouble of swapping heads and headers and not install an aftermarket base & runners.
Good luck with your mods.
Old Jun 7, 2006 | 08:42 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Old Jun 8, 2006 | 09:30 AM
Don 79 TA's Avatar
Engine: TPI
i figured since i am using the stock cam, and very mild heads, then the stock intake/plenum would be fine, even if i went with a real mild cam
trying to use what i have
i've heard the stock tpi setup, is good for 350-400 hp, especially if it's tweaked out
now if it's beneficial to use the edlebrock one, then i would
wasn't sure if it was warranted on the setup, plus trying to stay away from getting extremly involved with ecm changes
Old Jun 8, 2006 | 11:54 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Mine is ported and siamesed . It's 4"deep . Some have gone farther .
Here is some pics
Here is the plenum ...also shows how much bigger the new runners are .
MantyZ28
16
Dec 21, 2015 11:02 AM
stalkier
Dec 6, 2015 11:25 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
Sanjay
Aug 12, 2015 03:41 PM
