My ALDL has no pin "G"! How to test fuel pump?
Old Jun 8, 2006 | 11:19 PM
TEKNOSYS's Avatar
Car: '91 Z28 1LE / '04 Subaru WRX
Engine: L98 5.7l / EJ20 2.0l Turbo
Transmission: 4L60 / 5MT
How else could I check if the fuel pump is bad if my ALDL port has no pin in socket "G"? This is on a '91 Z28 1LE. Thanks
Old Jun 10, 2006 | 08:12 AM
Vader's Avatar
You can power the pump directly at the relay socket with just a jumper wire.
Old Jun 10, 2006 | 11:02 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
The red wire is located over by the timing plug, it has a black connector on it.
That is the fuel pump prime wire.
Old Jun 10, 2006 | 11:14 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
On my '91 TPI its on the drivers side by the relays.. On my brothers '91 TBI, it was on the passenger side by the timing connector.. Red wire with a female blade connector on it.
92camaroJoe
Jul 29, 2023 07:57 PM
89GTAOz
May 16, 2020 09:31 AM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
