ERG head question
Old Jun 9, 2006 | 01:23 AM
cutnsick's Avatar
Car: 88 GTA Pontiac right hand drive
Engine: 350 CI
ERG head question
Just a quick one, Can I use non erg heads on a stock tpi base without any other modification
Old Jun 9, 2006 | 02:38 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Your going to need a vette base because it has the ported egr from the exhaust on it from the factory.
Other than that yes, just have to put a pipe from the header to the intake and away you go.
later
Jeremy
Old Jun 9, 2006 | 06:57 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
FYI - Scoggin Dickey sells a kit for non-EGR heads on a TPI motor.
Scoggin Dickey at Sdpc2000: Performance Parts, Racing Engines, Racing Engine Parts, Race Engines, Race Engine Parts - SDPC
Hope this helps.
Old Jun 10, 2006 | 01:11 AM
cutnsick's Avatar
Engine: 350 CI
Can i just whack them on and not connect it up?
Old Jun 10, 2006 | 03:43 AM
3.8TransAM's Avatar
I wouldnt just block EGR off and not use it unless you are turning it off 100% in the chip.
Several different routines run when EGR is on, so it is best to eliminate it 100% iof not using it.
later
JEremy
MustangBeater20
Oct 29, 2022 09:20 PM
Mickeyruder
Sep 2, 2015 02:45 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
