TPS sensor?
Old Jun 16, 2006 | 12:56 AM
K.KING's Avatar
TPS sensor?
New to the world of TPI and in the process of building a system to put on a older car. I've done a lot of research and have read about the TPS sensor. I understand what it does, but i have not read anything that described it or mentioned where it should be placed on the engine. Can anyone help?
Old Jun 16, 2006 | 05:12 AM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
It is located on the passenger side of the throttle body, just above the IAC sensor. It has a three prong connector, should be a black, grey, and blue wire from the harness. Look for a book called TPI Swapper's Guide. It will clear up a lot of questions.
Old Jun 16, 2006 | 10:31 AM
K.KING's Avatar
Thanks that helps alot.
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
bbsr72
Apr 2, 2016 09:12 AM
Fred SS
Oct 12, 2015 11:27 AM
BWilcox
Sep 20, 2015 12:19 PM
