Fuel Injector Clip broke....what now!!!!!
Old Jun 24, 2006 | 10:42 PM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
Well I have been in the middle of swapping my old l03 for my new modified L98. I hooked up the battery thinking today its going to crank for the first time...wrong! I had a huge leak from the number one injector. Like gas was sprying over the engine, straight out over the radiator, thanks to my new walbro fuel pump that I installed this morning also. Anyways I took the injector loose and replaced an O-ring, which was brand new anyway. Went to out the clip in and it snapped in two. So no one in town here carries fuel injector retainer clips, do dealerships usually have these in stock?? Do I even need it?? The other injectors do not leak but they all have clips on them also.
Old Jun 24, 2006 | 10:45 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
I have 8 injectors not one has an injector clip. Ive set my adjustable regulator up to 60 psi and not one has leaked yet.
Old Jun 24, 2006 | 11:04 PM
techno101's Avatar
Car: 1989 Camaro RS
I have an adjustable regulator also, do you think I should tighten the screw and crank up the pressure, and try the one injector without the clip? Should the injector slide up into the rail or make a pop or something?
Old Jun 24, 2006 | 11:08 PM
shaggy56's Avatar
Car: 71 Nova
As long as the fuel rails are tightened down they shouldnt leak.
Old Jun 24, 2006 | 11:27 PM
JB22's Avatar
The SVO Injectors from Fiveomotorsports tell you that you cant use the OEM injector clips anymore. It states to bolt the fuel rail in and then equalize the injector between the intake and the fuel rail.
with that being said, you really dont need them. If the fuel rail is bolted in, its not going anywhere.
Old Jun 25, 2006 | 07:04 AM
techno101's Avatar
Car: 1989 Camaro RS
Yeah I am using SVO motorsports Injectors. Venom Pythons to be exact. I will try and snug the injector without the clip. Let yall in on what happens later this afternoon, thanks for the help!!!
Old Jun 25, 2006 | 02:41 PM
techno101's Avatar
Car: 1989 Camaro RS
Got it, no more leak!! Thanks everyone!
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
