Faulty TPS??
Old Jul 12, 2006 | 02:00 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Faulty TPS??
Jeez...one thing after another since having the engine replaced. If you are knew to my woes here's the story:
Put in a 350 in place of the 305. My timing was too far advanced, I had a broken ignition rotor, my afpr was set at like 60psi. This was all when I got the car back. I found all these things after trouble shooting hesitation under load, some rough starts, and dying when coming to a stop [infrequently].
I set the timing to 6, replaced the rotor, and dialed back the fuel pressure to 44 psi.
Checked my TPS sensor (speed density) and found it to be a at .610v. I adjusted that to .710v. I checked it at WOT and it would read as high as 1.xxx. Isnt it supposed to increase to 4v under WOT? I was doing this with the car in park and turning the throttle lever at the TB.
Old Jul 12, 2006 | 02:03 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Isnt it supposed to be set for .54 No throttle?
Should be near 4.5 volts WOT and if u see any 0.00 in between closed throttle and wot its time for a new one
Old Jul 12, 2006 | 02:06 PM
.54 for maf and .71 for SD right?
I'll recheck it again. I couldnt get it past 1v on wot. I'll check for any 0.00 reading
Old Jul 12, 2006 | 08:55 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
i had no clue sd and maf system's used a different tps readin
Old Jul 12, 2006 | 09:54 PM
I read a tech article at iroczone about it. I hope they were right
Old Jul 13, 2006 | 02:07 PM
HD4mula's Avatar
My manual says it should be around .5v closed and 4.5-4.9v WOT. SD here.
Old Jul 13, 2006 | 03:43 PM
This is where I got mine from.
Tech Articles - Adjusting Your TPS
I dont know.
Either way, can you monitor the voltage while in park and revving via the throttle at the TB?
And do you really need to adjust IAC on an other wise stock engine?
Fanatic1074
Oct 3, 2022 05:57 AM
sheachopper
Jul 31, 2019 11:27 AM
BumpaD82
Feb 26, 2016 02:57 PM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
