Anyone have knowledge of "Comp Cams Extreme Fuel Injected Cams"?
COMP Cams, Camshafts - summitracing.com
The first 2 cams look very interesting. I have been researching them. They might be a good alternative for the LPE 219 with a SR/TFS heads.
My ported SR should be shipped in a few days time. Time to pick out a cam. A few guys on the thirdgen board have had success meaning in the 370-380rwhp with 350-355 cubes. Who has used these cams, and were you happy?
CCA-08-466-8 218 int./224 exh.0.570 int./0.565 exh. lift 113lob seperation
CCA-08-467-8 230 int./236 exh.0.576 int./0.570 exh. lift 113lob seperation
Springs on my heads are good to .600 so says TFS. So those cams would need 1.5's. 1.6's might be too much lift. I think these cams might be something for you guys to think about to think out of the "219" box. Just some info!
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Originally Posted by HD4mula
I'm interested on this too. As far as I know those lifts that you listed are with 1.6 rockers and not 1.5.
COMP Cams Xtreme Fuel Injected Camshafts: CCA-08-467-8 - summitracing.com
[Intake Valve Lift with Factory Rocker Arm Ratio: 0.576 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.570 in. ]
EDIT:
Crap...more info posted wrong on their site (Summit) 1.6 it is!
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Originally Posted by madmax
That is correct.
http://www.compcams.com/technical/Ca...67_226-227.pdf
and look on page 142.
Car: 1986 trans am
Engine: 383 hsr
Axle/Gears: 3.70
i have a comp xfi flat tappet cam 224, 231 duration, 520,515 lift on my 350 with a stealth ram and i love it. it pulls hard all the way to 6,200. the tech rep of comp recommended the xfi cams over the other tpi cams they make. i also just passed emissions with it.
Originally Posted by Dyno Don
Those are excellent choices.
Thanks, but which would u go with? I have stock 3.07 gears in my 4+3, and I am not changing them. I am thinking the 218/224 with .570 lift should make more power then the LPE 219. Would I be correct?
Car: White KSwisses
Engine: 5.3L Gen III
why?
It is not wise to use a performance cam with non perf. gears
84z96L31vortec
Aug 20, 2017 12:16 AM
