quck CSI question
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
quck CSI question
I have a huge vacume leak at the cold start injector. Tommorow im going to try n flaten out the plate for it and try some RTV on it. My question is... if that doesnt fix the leak and I decide to just plug the hole, does the ECM have to be adjusted to eliminate the CSI or can I just unplug the electrical connection to the injector? I read somewhere that it has its own fuse as well.
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
youll need the chip out of an 89, with vats disabled
Then you can either plug the CSI or cut the wires to it assuming you dont have a leak
Hope this helps
Hope this helps
Car: 86 T/A
Engine: 383
whats going to happen if I dont get a new chip? It will just run like s*%t till the temp gets passed 95 degrees?
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
