Aaaah, Help (emissions, did search)
Old Aug 29, 2006 | 03:19 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Hi, I just failed emissions with my new car.
HC was 4.59 limit 2.5
CO was 49.3 limit 20.00
Passed CO2 and NOx and everything else..
305 TPI jasper engine.
What does this tell you??? (New plugg wires, 6advanced, new cap and rotor, new coil, pluggs are gapped at .45 would that be the problem)???
I have the STOCK exhaust on the car right now!
I searched, but never came across someone who had CO and HC's high like this. It was they either passed one or the other. Most of the posts end abruptly without any results of what other members suggested.
So,
How does denatured alcohol work?? How should I use it??
Any tips on passing???
(New pluggs are coming tommorow).
Old Aug 29, 2006 | 04:24 PM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
replace ur o2 sensor it may be a lazy sensor ( going bad but not bad enough to trip SES) then get some fuel injector cleaner 2 lil things that may help
Old Aug 30, 2006 | 01:24 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
you are rich.
FireBirdKnight, is right, replace your O2 sensor. i recommend using an A/C delco sensor.
also check your fuel pressure, too high will cause a rich condition.
check the fuel pressure regulator to see if it may be leaking.
your cat may also be weak or dead from a bad O2 sensor or fuel pressure regulator leak.
Old Aug 30, 2006 | 03:33 AM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Yeah, O2 sensor, and maybe the cat.
jaridjohn
Oct 5, 2015 07:01 AM
racereese
Oct 3, 2015 03:46 PM
paul_huryk
Oct 1, 2015 04:27 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
