Question about timing
Old Sep 3, 2006 | 08:13 PM
86WhiteIroc's Avatar
Car: 1986 IROC
Long story short, I had to replace the timing gears on my TPI 305. I got it started but was worried about the timing, so I bought a timing gun and tried it on the engine, using these instructions: https://www.thirdgen.org/settingtiming
But then I came across this post in the 'Banned topics' thread:
Quote:
Originally posted by Ed Maher
Q2: Where should i set my timing?
A2. Read A1 and pretend timing is setting the AFPR
Ed, timing is set in the ECU on a TPI car. It is only adjustable by reprogramming the prom.
Changing the base timing at the distributor is only lieing to the ECU and could hurt perfromance.
So these two seem to contradict themselves. I haven't changed the timing, only looked at the blanacer with the timing gun. Can you tell me which one is right? Because the timing measurements on the engine are at about 2oclock relative to the balancer, but the timing marks on the balancer are at about 11oclock. What should I do?
Old Sep 3, 2006 | 09:01 PM
voodoo7869's Avatar
Car: 91 formula converted to ws6 ta
Engine: 350 chevy
Transmission: 5spd
The correct way to do the timing is to set the engine timing to whatever it says on the smog label with the esc bypassed so there is no electronic advance. If the smog label has no marking for timing set the car to 0 deg advanced. the ecm will take over from there. If you set the timing to anything other than what the smog label says the ecm will still think the car is set to the smog value even though it will be different. for instance if the smog label says 0 deg and you set it to 4 deg then the computer will be over advancing the motor by 4 degrees because it thinks it is at 0. This can be a very dangerous condition because detonation is highly likely.
Happy
Old Sep 3, 2006 | 11:18 PM
Car: 1986 IROC
Ok thanks, I'll try that tomorrow morning.
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
