Need some advice on 350 change over.
Old Sep 8, 2006 | 06:51 PM
Padawon's Avatar
I'm replacing my tired 305 with a roller 350. I'm keeping the TPI.
What I have is a roller 350 with a ZZ4 pullout cam, flat top Hyper. pistons, completely rebuilt tpi with 22lb '03 Mustang GT injectors, and a set of 192 casting heads (I neglected to tell my builder that I didn't want that casting).
I have the auto tranny and 3.23 posi rear end.
What issues do I need to be looking for at this point and what can I expect from this motor as in idle quality, performance, etc.? This has been a four year long parts buying mission and I have been pushed into making a few rush decisions in the last week because the 305 was crapping out quick. I just want to make sure I don't make a mistake before I get the motor put in. Thanks in advance.
Old Sep 10, 2006 | 02:38 AM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
Hmm.... well can we get some idea of what kind of a setup you have with your 305? What year, MAF or MAP, just need a place to start before making rash decisions. Basically, it all depends on what you want to do with it, whether its street or strip or just something to tear up on the weekends. One thing you will hear a lot, junk those heads, or try to make ends meet with what you got. Post a little info to see what your working with.
Old Sep 11, 2006 | 08:02 AM
Padawon's Avatar
Sorry, I was in a hurry and forgot to give you guys good info.
It's an '86 IROC so it is MAF system. I'm just looking for a good torquey motor for use on the street. This is actually my daily driver. I do Autocross some but need torque there too.
I'm not too worried about those heads as I won't be pulling enough rpm's to notice the drop off in flow. The budget is getting low now, too, so I'm prolly gonna have to make em work.
Old Sep 11, 2006 | 11:42 AM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
read this link; 305 TPI to 350 TPI Conversion
it should help you answer many questions on what you'll need to do/change.
...and good luck, I'll be doing a 350 conversion in the near future!
Old Sep 11, 2006 | 01:30 PM
Padawon's Avatar
Thanks a bunch. That is a handy link.
Does anybody have any experince with getting proms burned and have any suggestions on who's reputable? The company that used to do it here doesn't do it anymore.
Old Sep 11, 2006 | 01:36 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
you can do like i did and get a Jet chip.
just get the chip for the vette. its programed for 22lb injectors thou.
it should work well, and it only cost me $124
xkingcodex
Feb 12, 2020 07:43 PM
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
BlackTopKing
Aug 19, 2015 12:13 PM
jbd1969
Aug 17, 2015 07:06 PM
