Coolant temperature sensor problems - non-original motor on 92 RS B4C maybe?
Old Sep 23, 2006 | 05:07 PM
ecetim's Avatar
Car: 92 RS B4C - needs lots of work!
Engine: 5.7L L98
Transmission: 700R4?
Question moved to here:
https://www.thirdgen.org/forums/hist...gine-92-a.html
Attached Thumbnails Coolant temperature sensor problems - non-original motor on 92 RS B4C maybe?-plugs.jpg
Old Sep 24, 2006 | 11:51 AM
f1ls1's Avatar
Car: 1999 F-1 Camaro Conv 1990 Iroc-Z
Engine: LS1/L98
Transmission: A4/A4
Axle/Gears: 3.23/3.27
The two wires go to the diverter valve.
Old Sep 24, 2006 | 12:00 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
your fan switch should be between the 6 and 8 exhaust exits. not in the front of the manifold.
sounds like you have a wiring nightmare.
Old Sep 24, 2006 | 12:06 PM
ecetim's Avatar
Engine: 5.7L L98
Thanks guys, I've gotten some good help in another thread:
Hopefully will have all this figured out by tomorrow, I'll update then!
Old Sep 28, 2006 | 05:31 AM
Pat Hall's Avatar
None of the 92 F-bodies got aluminum heads. Only the Corvette TPI motors got the aluminum ones. The only temp sensor that's towards the back of the engine would be the intake air temp sensor, which is located on the underside of the tpi intake plenum. Btw, it's identical to the coolant temp sensor, but it measures air temp instead of water temp. Since whoever owned the car before did away with the AIR system, that's why you have those white and green plugs just hanging there. They go to the smog pump diverter valve. You might want to check and see if the wire is still hooked up to the cooling fan switch located between #6 and #8 spark plugs on the passenger side head. Try grounding that wire to see if the fans come on. If they still don't come on, probably check the fan relays next.
eightsixseven
Dec 16, 2024 01:50 PM
jhawkeye
May 25, 2022 06:33 PM
zeitghaist
Aug 18, 2015 07:33 AM
fonzie85
Aug 13, 2015 11:50 AM
