Hi. I have a 87 350 tpi. I want to buy new injectors but i dont know what to buy. I want better performance and maybe a chip from the same place. where to buy and what fuel pressure shoud i do???
Ole
1966nova
Ole
1966nova
Stay away from Accell injectors.
Stick with SVO/Ford Racing.
IF you have a 305 you can get 19#'s, if you have a 350 you will have to get 24#'s and for best results you should get the injector constant in the chip changed.
I would recommend learning how to do your own chips, just take a look at the PROM board here. For less than what a "custom" chip costs you can be doing your own.
later
Jeremy
later
Jeremy
You could also get SVO 22lb. injectors. For a stock 350 with no PROM mods they would be probably be a better choice than the 24lb.
I bought a set of 24# from a LT1 for my 305. They seen to work pretty good. 1 year old and only paid $100.00 for them.
Ok thanks. I think i go for the 24# injectors and learn me some chip burning too. Any sugestions for a good and cheap chip burner???
