fuel pressure question
Old Oct 10, 2006 | 01:15 PM
BadIroc's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 Crate Motor Holley Stealth Ram
Transmission: WC T-5
Just wondering going from 19 or 22 lb injectors to 24lb injectors do you have to turn the fuel pressure down? Seems like my car is running rich basically start crying when walking behind my vehicle everything is in check 02 sensor is brand new....thanks
Old Oct 10, 2006 | 02:28 PM
ROCITUP's Avatar
you need to reprogram.......I wanted to do the same thing but could not.
Old Oct 10, 2006 | 09:41 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
My 305 had 24's on and the exhaust wasn't that bad after I put on the MSD digital 6plus ignition.
Oh, and I had the fuel pressure on the stock setting on the afpr
Old Oct 11, 2006 | 12:09 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
I installed 22 lb SVO's in my 1987 305. If I set the injector constant in the PROM to 19 lb's the exhaust smells very rich and burns my eyes. When I set it to 22 lb's it runs well and the rich fuel smell goes away.
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
