TPS TUNING
Old Oct 11, 2006 | 03:21 PM
ROCITUP's Avatar
TPS TUNING
HEY WHATS UP ? IF I MOVE THE THROTTLE WITH MY HAND SHOULD THE VOLTAGE MOVE VERY SMOOTHLY PAST 4.0 VOLTS OR DOES IT EVER STICK OR JUMP JUST A BIT? WHAT DOES YOURS DO ? ALSO IVE READ THAT .54 IS RECOMENDED AT IDLE FOR STOCK BUT WHAT ABOUT MY 383 COMBO,HEADERS ,EXAUST,AFPR,22.8 LB INJECTORS? WHAT DO YOU GUYS RUN AND WITH WHAT SETUPS?........MANY THANKS.
Old Oct 11, 2006 | 09:49 PM
Damon's Avatar
Voltage increase with throttle opening should be very smooth and progressive. Little "blips" in the voltage curve I would take as a sign that the electronic guts inside the TPS are getting flaky and it should be replaced.
You shoot for the same voltages with a modified motor as you do for a stock one. The TPS isn't a tuning tool- it's either set properly to give the ECM a true indication of throttle position from idle to WOT or it's not.
Old Oct 11, 2006 | 10:36 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Exactly, should be a smooth motion. At no point should the number just jump sporaddically. You should get to just about over 4.
Old Oct 12, 2006 | 10:02 AM
ROCITUP's Avatar
YO, THANKS A LOT FELLAS......YOU ANSWERED MY QUESTION PROPERLY. IM GONNA REALLY CHECK OUT MY TPS AGAIN BEFORE I BUY ONE BUT THEY ARE KINDA PRICEY TO JUST CHANGE OUT FOR NOTHING. BUT THANKS AGAIN GUYS...........IM OUT
sammy52401
Nov 11, 2015 07:20 PM
92camaro350cci
Oct 14, 2015 09:29 AM
BLK87Z
Sep 18, 2015 11:29 PM
