fuel pressure and timing
Car: 1988 IROC
Transmission: 700 R4
Axle/Gears: 2.77
I am putting an AFPR on and right now my psi is 35, everything I have read on here says between 47 and 50 psi, the car has headers, mild cam, head porting, and a hypertech chip. Sound right?
Can I adjust the base timing even with that chip? It is at six right now, how much should I advance it at 5000 feet elevation?
Also has anyone tried the Kirban throttle performance switch from the Ecklers corvette catalogue on a Camaro?
Corvette Throttle Performance Switch, 1982-1991
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
42 psi should be your minimum for good fuel atomization. The higher pressure gives you better spray pattern / better fuel atomization. Leave your timing where it is with the Hypertech chip.
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
