SPLIT PERSONALITY
Old Oct 27, 2006 | 05:38 PM
Domestic_Muscle's Avatar
SPLIT PERSONALITY
I recently did a tune up on my IROC TPI 305.
When I pulled the plugs the left hand side of the motor was running lean and the right hand side was running rich.
Has anyone incountered this issue, and if so how did u diagnose the problem.
Old Oct 27, 2006 | 07:24 PM
Guest
Guest
Posts: n/a
Lean and rich by how much?
I'd check to see if the injectors are firing properly and that nothing is shorted out.
Old Oct 28, 2006 | 06:52 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
If all of the plugs in a bank are running lean and the other rich, the problem is in the rail, regulator, or return line. Take the rail off and clean everything out and try replacing the regulator diaphragm and such. Does the car run as it should? No loss in power?
Old Oct 28, 2006 | 05:18 PM
the only issue with the car right now is back firing when im downshifting. but no power loss, as far as im concernd its running great, i wouldn't have noticed till i did the tune up
MrPackstin
Oct 25, 2017 08:09 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
1992Z28!
Nov 19, 2015 07:33 AM
MantyZ28
Nov 8, 2015 06:54 PM
87hellbird
Sep 14, 2015 05:08 PM
