Another Cam Thread
Old Oct 28, 2006 | 09:48 PM
Rich92 RS's Avatar
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
Another Cam Thread
I have an 86 Iroc-Z w/305 that’s stock, except for an Airfoil, Exhaust, and Air filters. You could say it’s a SS (Super Stock)
My question is: what should I look for in a cam? I don’t know anything about the cam style, duration, and lift. If someone could help me out with this that would be great.
Also if you have any recommendations on a cam please feel free to post your suggestions. Would an LT4 Cam work good?
Old Oct 28, 2006 | 11:52 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
the only the problem is that an LT4 cam is a roller cam, and your motor is not. you have a flat tappet cam style.
check comp cams out for some cams.
Link: http://www.compcams.com/technical/Ca...67_226-227.pdf
here's a few notes.
nothing less than 112 LSA(lobe seperation angle)
intake/exhaust @ .05 lift nothing over 220/230 (and those are farely high)
if you have a stock intake no more than 218/224
the valve lift is only restricted by your springs. comp sales a hole kit that will come with every thing you will need. like cam,lifter,springs,retaners,timing chain,and push rods.
you'll also have a choice to either, keep the flat tappet cam, or change to a retro fit roller cam(which can be very expensive)
well, good luck
and feel free to ask any more questions you might have.
Old Oct 29, 2006 | 08:08 AM
Damon's Avatar
Yeah, the 86 TPI motors got basically the same flat tappet cam as the old LG-4 carbureted motors. Affectionately known as the "peanut cam" around these parts. You can check out the tech section for specs but if memory serves, it's 179*/194* @ .050 (that's not a misprint- it's THAT small) on a 109* LSA and lift is under .400" on both intake and exhaust. Just about any cam you would buy would be a "fire breather" compared to the stock cam.
Even the smallest cam in Comp Cams selection of Xtreme Energy cams for computer controlled EFI small blocks would be a huge compared to what you've got now. Here's the link to the cam card for it:
Camshaft Specifications
It may not look like a very large cam but consider this.... it's got 27* more intake duration @ .050 than your stock cam! That, in cam terms, is a BIG change.
junkcltr
Aug 2, 2019 11:12 PM
Street Lethal
Apr 30, 2019 12:14 PM
camaro71633
Sep 1, 2015 10:24 AM
masonta
Aug 31, 2015 10:14 PM
LT1Formula
Aug 20, 2015 09:36 PM
