Question about A.I.R. lines...
Old Nov 12, 2006 | 02:09 AM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
Well today I had to remove my diverter valve over the passenger side valve cover to get to my gasket. But since my cats have been removed and I dont need to take emissions tests,,, I wanna just remove the smog hoses and etc. But my question is where can I find a fitting to block the hoses that lead into the exhaust manifolds? I wanna just cut the metal pipes leading into the manifolds also. But I dont want any leaks... What should I do guys?
Old Nov 12, 2006 | 09:36 AM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
so one asked about this a week or so ago
Old Nov 12, 2006 | 10:34 AM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Yeah, at first I was trying the wrong search criteria. But I got it all figured out now. I think.....
Old Nov 12, 2006 | 11:30 PM
dave-92gta's Avatar
Car: 92 trans am/ 93 dodge spirit V6
Engine: L98 V8 - 350
Transmission: TH-700-R4
you want to take the egr lines out of the manifold...well tehre are 2 options... heat your car up, go for a drive, when they are got jsut bend the egr valve back and forth until it breaks off. grind down the holes till you get them flush and weld closed. or unscrew them and put a 1/4 plug in there. you can get those plugs almsot anywhere. here in canada, canadian tire was the cheepest. at the same time take the smog pump off, not hard to do. there is not a really got tech article on taking it off but you will need to get a new belt once this is done.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
