No SES light!!!! Help!
Old Nov 28, 2006 | 07:54 AM
1987earthquake's Avatar
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
Ok guys I just finished up my swap. I swapped in a 355 tpi where a 305 lg4 used to sit. The car is a 87 camaro. all the dash wiring was the same for both the tpi and the lg4. besides a couple wires i had to run seperate. for the most part it went pretty good. I got a 305 tpi setup on top of my 355. When i turn the key to the on position the SES light doesn't come on. It even stays off when I crank it up. I deleted all A.I.R. stuff, egr blocked off, have not connected my maf yet, have not connected my o2 yet, or my mat. I thought my light was supposed to come on if the egr is not connected. I plan on putting a new cluster in this evening. I'm switching from a 85 mph to a 145 mph cluster.
Old Nov 28, 2006 | 08:13 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I am not sure about the camaro, but the Firebird LG4 and LB9 were totally different as far as dash wiring. The IP, radio, electric mirrors etc was the same, but beyond that not much else was.
When I did my swap I used the original dash from the donor car. It was much easier and I had no issues with it. Starting in 1988 all cars had EFI so it may be that less would need to be swapped but thats speculation.
John
Old Nov 28, 2006 | 11:17 AM
Engine: 5.3L
Axle/Gears: 3.42LSD
I actually pulled the dash completely apart and traced the wires back. They were both wired the same. I just want to know why my ses light is not coming on. I even checked the pin on the ecm plug and didn't get juice. I used a 12v test light. It's supposed to have 12 v going to this pin according to chevythunder.com
Old Nov 28, 2006 | 05:45 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
The SES light is supposed to have 12 volts with the key on, and the ECM will supply its ground to turn it on. In other words, the light will always have 12 volts, but only sometimes will have ground. You will not get 12 volts out of the ECM on the SES pin.
Your problem is either a power supply problem to the SES light, a burnt bulb, or a mismatch on the pinout between the dash harness, and the TPI harness at the 15 pin dash connector.
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
