Can I Remove the Activated Charcoal Filter?
Is it possible to remove the activated charcoal filter from our cars? Is this possible? Advisable? I'm doing an engine swap at the moment and am looking to clean up the engine bay a little.
The car in question is a 1989 350ci TPI?
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Depends on where you live. Emission laws ect. Mine went in the trash when I installed my SLP intake. I cut the wires short, and taped them up. Plugged the lines. Ive had no problems.
Car: I've had 4 thrid gens!!
Engine: Someday again I will have another!!
If you do a search, there is a lot of threads on this. I remember reading the factory put the can there for a reason. Your gas tank needs to be able to vent gas fumes. If you take it out, you should really get a vented gas cap.(the stock one is not vented, because we have the evap box).
I'm not worried about emissions or anything, regarding the canister removal.
Would I have to vent the gas tank in another way if I removed it?
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
The basic function of the EVAP canister is to collect fumes from the tank and purge them into the throttle body at given times. The fuel tank has its own vent just in front of the tank. Just that I have never understood why it still hisses when opening the cap. If you still want all that you can get for your fuel economy, I would keep it in place. I have heard of them being relocated for the cleaned up look and the fuel economy. Just where would you put them?
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
