What sensor is....
Old Jan 5, 2007 | 05:13 AM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
What sensor is....
Directly above the starter, between (and slightly above) the rear 2 spark plugs on the passenger side?
It only has 1 wire coming out...Im thinking temp gauge?
91 z28 w/ 350
(Edit: Sorry, wrong forum...meant to post in general engine)
Old Jan 5, 2007 | 05:16 AM
hot92RS's Avatar
Car: 92 Z-28
Transmission: THM700R4
it is the temp sensor that tells when to turn on the radiator fan.
Old Jan 5, 2007 | 05:37 AM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
And thats different from say..."coolant temp"?
I ask because I had bought the connector for it, because when we took it off, it broke...so 6 months later, we realized that the plastic ring that was part of the sensor itself was ALSO broke...so I needed a new sensor...
The parts guy and I both looked through their wells book at autozone for over 30 minutes and couldnt find it...I even had the connector with me...and he still couldnt find it, and I didnt know what sensor it was
This page says "The secondary fan has its own temperature sensor in the bottom of the engine block (passenger side) The Auxiliary Coolant Fan is controlled by the A/C Pressure switch and the auxiliary coolant fan switch. It is not controlled by the ECM. It should have black and black/pink wires going to it, and the coolant fan will have black and black/red wires going to it."
https://www.thirdgen.org/third-gen-engine-fans
The sensor Im talking about only has 1 wire going to it, is it the auxiliary coolant fan?
Last edited by lizardkng; Jan 5, 2007 at 05:48 AM. Reason: Added info from fan faq.
Old Jan 5, 2007 | 11:05 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Ya, if it is in the head, with one wire it is the Temp Switch for the fan, it has the same type of connector as the knock sensor which is in the block about maybe 8 inches down from the switch in the head.
mine had the connector and part of the sensor break apart on my car, but since my temps never go over 220 (stays at about 170 all the time) , I don't plan on replacing it. Secondary Fan Switch is in the 240* range I believe.
I do have manual switches hooked up to both of my fan relays so that I can turn either or both of them on whenever I want also. the switches are wired to ground and to the ground terminal on the relays (green wires).
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
