fixed the idle but.....
Old Jan 10, 2007 | 10:08 AM
1BadaGTA's Avatar
Car: 1991 Gta trans am
Engine: 383ci,trickflow alum. heads, hsr
Transmission: T-56, alumin. driveshaft
Axle/Gears: stock 7.5"/3.42
I fixed my idle I had a leak in the intake manifold gasket. But now when I jump on it the car feels like it wants to go but something is holding it back? It'll start to go then start backing off alittle and go alittle more then back off alittle and it keeps going like that and I doesn't matter what gear I'm in. Any Ideas? I thought it might be the fuel filter.
Old Jan 10, 2007 | 03:17 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Could be, any way you can check your fuel pressure?
Also could be some bad plugs or wires.
But make sure you dont have another vacuume leak.
Old Jan 10, 2007 | 09:28 PM
1BadaGTA's Avatar
Well I just gave it a tune up and it never had this prob. before the headers were put on my dad and i try jerry riggin the stock down pipe to the hooker headers the passenger side we twisted up pretty bad could It be that the exhaust flow is getting messed up because of it and causing it to lag like that? And I replaced the fuel filter and it didn't help. But how would I check the fuel pressure?
theshackle
Sep 17, 2020 08:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
86IROC112
Aug 17, 2015 02:00 PM
