Power steering pump.
I recently installed some shorty hooker headers on my Iroc now my power steering pump is loose is there anything I can do to mount it back up properly without the a/c compressor bracket? Thanks
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
You must re-install all mounting brckets that deal with the power steering pump. However, you can cut part of the one bracket off if you have removed the AC compressor. So to answer your question directly, I say NO.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
all you need a a non a/c bracket that bolts to the exhaust manifold, you spacer it out with a longer bolt for the first header bolt hole this bracket was really common in the 70s
or just weld up a piece of metal real quick to use
no big deal
good luck
no big deal
good luck
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
backtothe80s
Sep 5, 2015 12:39 AM
sailtexas186548
Aug 24, 2015 10:11 PM
