Vortec 383 help...
Old Jan 28, 2007 | 08:25 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
Vortec 383 help...
Hey Guys, I currently have a stockish L98 that I plan on replacing with a 383. I already have a set of slightly used Vortec heads with .520 comp cams springs installed on them. Does anyone know of a decent stroker short block that can be had for reasonablly cheap? I would like to find something with a cam, flexplate, and balancer already installed to speed up the installation process. I also plan on getting the SDPC TPI base, SLP runners, SVO 24 lb. injectors, and SLP headers. I see strokers on the GM performance website but they are all $3,000 or more. Gustafen engines.com has cheaper 383's but they don't come with balancers or flexplates installed... Does anyone have any suggestions?? Thanks!
Old Jan 29, 2007 | 06:41 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
http://www.coasthigh.com/Assemblies/Chev/chev_383.htm
http://www.ohiocrank.com/short.html
That's all I know of.
Your cheapest option will be building your own with used parts. Get a junkyard 350 and a crank, pistons and re-use everything else that you can, like the rods, but with better rod bolts.
Old Feb 4, 2007 | 09:57 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Thanks 383... Those 383's are looking rather tempting!
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
