Super Ram Upper With Vortec Baseplate?
Old Jan 30, 2007 | 05:36 PM
honkeytonk_man's Avatar
Car: 1988 IROC-Z
Engine: e-tec headed ZZ-4 350
Transmission: t56
Axle/Gears: 9 bolt 3.7 posi
Is anyone running a SDPC Vortec Baseplate with a SuperRam upper? Did it Bolt up Hassle free?
Old Jan 30, 2007 | 09:15 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
I am running the Superram upper and the SDPC vortec base and it does not bolt up hassle free. You need to counterbore the drivers side (2) rear most intake to head mounting holes, and the passanger side (2) most forward mounting holes to clear the runners. I also believe I had to grind on a few other spots to clear the runners but it did work out in the end.
Brian
Old Jan 30, 2007 | 09:20 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
...other words typical for a Super Ram regardless of the intake used.
88SS6SPEED
Nov 11, 2015 07:05 AM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
