Connector Identification
Old Jan 31, 2007 | 09:57 AM
87POSGTA's Avatar
Car: 1989 Firebird
Engine: 5.7 Vortec HSR
Axle/Gears: 9-bolt 3.45
I'm used to 87-86 TPI Units on my previous cars with totally different connectors. i recenly added a semi-complete 91. ive wired everything up but cant get power to the ECM. Im pretty sure its because of this connector here. Am i correct and also how does it connect to the battery(if it even does).
Old Jan 31, 2007 | 10:19 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
The connector on the left is for the ECM/FP fuse. The larger connector....not sure what it does but it gets hooked to a connector that's in the convoluted tubing with the battery power wire.
Old Jan 31, 2007 | 12:30 PM
87POSGTA's Avatar
Car: 1989 Firebird
alright, so the connector on the right side of the picture would get power at both of those ends correct?
Old Jan 31, 2007 | 02:26 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
As stated the smaller connector has a fuse in it with a cover that is fastened to the radiator support. The larger plug goes directly to the battery. The 90-92 Firebird battery cable has a plug that attaches directly the large plug. Yes both of the wires in the larger plug get power from the battery. If you had the aforementioned battery cables it would be a direct plug in.
Old Jan 31, 2007 | 02:37 PM
87POSGTA's Avatar
Car: 1989 Firebird
bingo would you happen to know where i could get this battery cable? from the way my luck goes im pretty sure that im going to be SOL on this one and have to get one off of a '92 F-Body.
Old Jan 31, 2007 | 02:43 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Aside from the dealership or someone on here I don't know. You should do a search for a part number. Maybe someone has one laying around. I had one but, a friend needed it for his car.
Old Feb 1, 2007 | 07:21 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
On subject.....
Where does the orange wire go? Mine's cut. Looks like the previous owner did something crazy with mine.
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
