sd code 41 service manual chart
Old Mar 19, 2007 | 06:18 PM
ducmon900's Avatar
Anybody have a link to a code 41 service manual chart...I have one for 86 maf but need a sd (map) one. thanks
Old Mar 19, 2007 | 07:43 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
the manual i have says its a cylinder select error, probable cause-terminal d3 of the ecm must be properly connected to engine ground for a v8 engine-disconnect the ECM C-D connector and probe terminal d3 with a test light connected to 12 volts. if it comes on,the terminal connection is faulty. thats all it has ,hope this helps,jimmy
Old Mar 19, 2007 | 08:23 PM
ducmon900's Avatar
that helps quite a bit...i'll give it a try tomorrow. Thanks Ken
BumpaD82
Feb 26, 2016 02:57 PM
eustodp
Sep 20, 2015 05:09 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
64Chief
Sep 12, 2015 08:05 AM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
