does anyone know were the supply fuse for each side of the injectors are on a 89 TPI
Car: 1989 Iroc Z28
Engine: TPI 5.0
Axle/Gears: Stock
I think i must be a fuse all 4 injectors are not working on the pass side . were is the supply fuse for each side located. the ones in the fuse box are ok and not the ones.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: does anyone know were the supply fuse for each side of the injectors are on a 89
If the fuses in the fuse box are good, then it must be a short or open in the wires. You'll need to do some continuity checking with an ohm meter.
Car: 1989 Iroc Z28
Engine: TPI 5.0
Axle/Gears: Stock
How should I go about that. should I just do the left side? and what kind of numbers am I looking for? what do I set the ohm meter on?
Ghettobird52
Jul 5, 2024 11:18 PM
Sanjay
Aug 12, 2015 03:41 PM
