fuel pump running with the ign off
Old Apr 16, 2007 | 08:27 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I am sure there is 1000 treads about this but i did not know how to go about the search
if you have a link to a thread or a way to search it or just a good idea let me know please
Old Apr 16, 2007 | 10:23 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: fuel pump running with the ign off
Check your oil pressure switch.
Old Apr 16, 2007 | 10:39 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Ditto. Probably needs replacing.
Old Apr 17, 2007 | 09:59 AM
jamon8's Avatar
Engine: 350 tpi
I just replaced the oil sender, it has to be something in the wiring
I wish the problem was easy but I think I have to go into the harness
I was hoping that someone had a similar problem
thanks for the quick replies
Old Apr 17, 2007 | 11:16 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Unplug the switch and see if the fuel pump shuts off. If it does, you've got the wrong switch, or your new one is defective.
Old Apr 17, 2007 | 02:42 PM
jamon8's Avatar
Engine: 350 tpi
yes Apeiron when I remove the connector from the oil sending unit the fuel pump does shut off.
I will get a new one and see whats, what
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
