Next mod??
Old May 9, 2007 | 05:48 PM
FormulaL98's Avatar
Car: 88 Formula, 72 Nova, 68 Chevelle
Engine: L98, mild 350, L79 327
Transmission: 700R4, M20, M20
Axle/Gears: 9b 327,10b 373, 12b 331
Next mod??
i recently added a new after cat exhaust to my car (edelbrock) and my car turned to 14.10's (down from 14.28 when i added the slp cold air). my question is what should be my next move?? I already has a AFPR which will be going on soon as i think it can now gain from the added fuel. Headers? Custom chip? What should i go with, now im anxious to go 13's.
Old May 9, 2007 | 07:54 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Re: Next mod??
I say headers 1st, port the plenum, port the runners, better intake (or port that too) And give it a nice tune.
If you have the time and $$, a nice cam would sound great!
Old May 9, 2007 | 10:31 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Re: Next mod??
I second porting, take out the EGR walls, siamese the plenum, radius the runner entries, smooth out the lower intake and cut off some of the radius at the turns *give the air a smoother wider path*. Turn up your fuel pressure and bump your timing 2 to 4 degrees. Headers are a must, I wouldn't call the exhaust job done until you get those.
Old May 9, 2007 | 11:02 PM
chevy boi's Avatar
Car: 1989 i roc-z28
Engine: 350 tpi l98
Re: Next mod??
long tube runners. i got the slps on my car and ported them to match the base and it pulls all the way to 5500. let that TPI breath
Some SFC if you dont already have them dose wonders for my launch , it felt like i was getting better weight transfer to the rear wheels
Old May 10, 2007 | 07:56 AM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Re: Next mod??
Headers I say.
Old May 10, 2007 | 01:29 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Re: Next mod??
Yeah i did everything in my sig.
Now I'm going to be putting some Sportline springs on and some SFC's.
I cant wait.
starliner
Feb 9, 2016 08:18 PM
Quzyle
Oct 15, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
